brake cylinder boot
brake cylinder boot
hi guys,i was changing my brake pads on rx330, i notised the the cylinder boots on the rear brake calipers are folded in place as if you put bigger boot in a smaller space.is that normal thank you
The boot around the piston has bellows like structure and it is flexible to allow movement and as the pads wear down can stay expanded. As long as they are not ripped/torn/damaged, I would leave them alone.
Salim
Salim
DanozLS430
11-07-16 05:46 AM
