Rear Rotors can not replace
My primary concern is that there are parking brake "parts" around rear rotors that either get in the way, need removed first, or are attached in a way that makes the rear rotors unable to just "pop off" like you said. I don't want to start on a job and find I am missing a part/tool.
And if you happen to know what size bolt, that would help as well.
Thanks.
Second. If you put the car in neutral and shut the ignition off, you won't be able to turn your key cylinder to the open position. Make sure to secure your other wheels so your car doesn't haphazardly roll off while you're bent over into the wheel well, but my rotor, which was pretty rusted, popped off on its own as I worked out the bracket bolt with a rubber hammer and wrench.
Rear Rotor RX350
Thanks everyone! This helped me remove rear rotors on my wife's RX. The bolts to use are 8mm x 1.25 pitch. Put penetrating oil around the hub then turn each bolt about a half a turn at a time each. Comes right off. The parking brakes are inside like someone said and look just like drum brakes. These were scrubbing a little making noise so I adjusted them when changing the pads, so she didn't need a bearing like she thought. Thanks again for the great tips!
Hey guys thanks much for all the advice. I want to share some more info so that hopefully more people don't make the same mistake I did!
There are 2 ways it can get stuck - rust/install press fit, and parking brake engagement.
To break the rotor off the hub use the M8 screws. Use good ones (8.8 or 10.9) or you might break the bolt and then you're stuck. Only screw them in a thread or 3, just enough to separare the rotor. The rotor hopefully will slide off easily now. If not - DON'T continue screwing the jacking bolts! The parking brake is stuck and you'll damage it (like me)!
To unstick the parking brake -
First make sure it's off (duh!
Pop out the rubber plug and rotate the hole to the bottom. If it's stuck, try putting a lugnut back on and using the tire iron.
When you get it to the bottom, look for a star wheel below the hole. Rotate it down, towards you with a flathead screwdriver. You'll hear a spring popping with each tooth.
Rotor should now slide right off.
If you're now reading this after you've already broken a few of the tiny parking brake parts... Sorry! But there is hope. I broke one of the aluminum spring caps and bent ont of the spring guide pins. Was able to take out the pin and bend it back with a pipe wrench. Same for the cap, was able to bend it back with a pair of tiny pliers. Getting it all back together is a mfer but is possible. If in doubt go buy new parts; you dont want it to fall apart on the road. Good luck!!
Rear spring, pin, cap, and washer
Star wheel location
Spring assembly after I bent it back
Star wheel location
Max Power
12
07-16-10 02:59 AM
