Replacement low beam light bulb
Old 12-17-09, 09:51 AM
steve83
steve83's Avatar
Default Replacement low beam light bulb
Hey everyone,
I'm new to the forums here. My mom is actually the one with the RX 330. One of the low beam light bulbs is out, it's a HID bulb, and the dealer was wanting a really high price to replace this bulb. I was hoping to help her save some cash and do this for her.
Does anyone know what bulb I need?
This is for a 2004 RX 330
Thanks,
Steve
Old 12-17-09, 10:37 AM
BurgBoxstr
BurgBoxstr's Avatar
According to sylvania's replacement guide, below are [most of] the bulbs required for the '04 RX330 w/ HID. Why not give a forum sponsor like XenonDepot (forget their new name) a shot. I bought their aftermkt kit for my GX and can't be happier.
Onto the bulbs:
2004 LEXUS RX330 (With HID (high intensity discharge) headlamps)
Low beam headlamp
HID-D2S
High beam headlamp
9005
9005SU Silverstar ULTRA for Ultra Night Vision - The Whitest and Brightest Halogen
9005ST Silverstar High Performance Lighting: The Whiter and Brighter Halogen
9005EB EcoBright - Your Environmental Choice
9005XV XtraVision Halogen - The Brighter Light
9005CB Cool Blue Halogen - The Whiter Light
Parking light
168
168LL Long Life Upgrade: Up to twice the life of the standard lamp
Front turn signal
992 (7440A)
Rear turn signal
992 (7440A)
Tail light
168
7443
Stop light
7443
High mount stop light
Assembly
Fog/Driving light
9006
9006SU Silverstar ULTRA for Ultra Night Vision - The Whitest and Brightest Halogen
9006ST Silverstar High Performance Lighting: The Whiter and Brighter Halogen
9006EB EcoBright - Your Environmental Choice
9006XV XtraVision Halogen - The Brighter Light
9006CB Cool Blue Halogen - The Whiter Light
License plate
168
Back up light
921
921ST Silverstar Signal Lighting: Complete the Look: Crisp, Clean, Style
921LL Long Life Upgrade: Up to twice the life of the standard lamp
Front sidemarker
168
Rear sidemarker
168
Glove box
74
Dome light
DE3175
DE3175LL Long Life Upgrade: Up to twice the life of the standard lamp
7443LL Long Life Upgrade: Up to twice the life of the standard lamp
Step/Courtesy light
2825
2825LL Long Life Upgrade: Up to twice the life of the standard lamp
Trunk/Cargo area
DE3022
Old 12-17-09, 10:46 AM
steve83
steve83's Avatar
Great! Thanks for that list.
I did a quick search in this section, and couldn't find any write-ups. Is it pretty easy to replace these bulbs? I've never poked around underneath that hood, but do a lot of maintenance for my cars.
Old 12-17-09, 11:47 AM
lexus114
lexus114's Avatar
I hope their not too hard to do,as mine are original bulbs as well.I wish I had an answer to your question,but have not tackled the job yet.(the older i get,the less I feel like doing this stuff any more) oh btw,if you replace the bulb and it still does not work.It may be the ballast/igniter or what ever their using now to start the bulb.
Old 12-17-09, 01:27 PM
mandyfig
mandyfig's Avatar
The low beam is a HID Lamp...hence pricey. Are there aftermarket replacements?
Old 12-17-09, 09:45 PM
mmlex1987
mmlex1987's Avatar
Steve I recently had my left front HID bulb stop illuminating and assumed it was just a very expensive buld, I was wrong it was the ballast. There are several threads pertaining to this subject. The first thing I would do is try the bulb that is working on the side which is not to determine if you in fact have a bad bulb. Changing the bulbs are a little bit more involved then a conventional bulb. Also, if the bulb is not the problem, I again suggest reading a few of the threads pertaining to the "head light computer" which is referring to the ballast. I spent much time in those forums and was glad I did because it saved me a bundle. I purchased my ballast on Ebay for $100.00 the oem Denzo number. Again the forums are very helpful. PM me if you want more info. The dealer will charge over $300.00 for the bulb and more than $1000.00 for the ballast or "head light computer" By the way the reason the ballast may go bad is from moisture and again I suggest thoroughly reading "all" the threads pertaining to the head light computer/ballast. Good luck.
Old 12-18-09, 09:25 AM
XenonDepot
Former Sponsor
XenonDepot's Avatar
Hi,
We sell OEM Philips HID D2S bulbs. Type in coupon code "KBXMAS09" to receive 10% off for a limited time only.
Steve
Old 12-18-09, 10:01 AM
lexus114
lexus114's Avatar
Originally Posted by XenonDepot
Hi,
Steve
Hey thanx Steve! Great site!
Old 12-18-09, 11:40 AM
XenonDepot
Former Sponsor
XenonDepot's Avatar
My pleasure =)
Old 12-19-09, 03:26 PM
fw1
fw1's Avatar
does anyone know if these bulbs would be covered under lexus extended warranty program?
Old 12-19-09, 03:42 PM
kitlz
No, I don't play soccer!
kitlz's Avatar
I'm not sure since I have yet to have a headlight bulb burn out on my 1st gen and 2nd gen RX. The headlight itself is covered under extended warranty. I would assume the bulb is included since tail light bulbs were changed out at no charge.
Old 12-20-09, 06:37 AM
mandyfig
mandyfig's Avatar
Lights are not covered by the extended warranty. As well as tails, signals, etc.
Old 12-22-09, 10:26 PM
mmlex1987
mmlex1987's Avatar
I agree all the bulbs are "wearable items" and not covered. But what about the Ballast or as some would call the Headlight Computer? Those should be covered as they are an electrical component, right?
Old 01-20-10, 07:57 PM
keycard198
keycard198's Avatar
I happen to have the Sylvania 9006SU around from my old Rav4-before switching over the lexus RX 330-2004. I believe these should work on the driving lights---
Question: How in the world do I switch them if I decided to...just curious..
Thanks
KC
Old 01-21-10, 04:37 AM
veleno
veleno's Avatar
My dealer told me my high beam bulb is covered under warranty, 4yrs/50k miles. I did not ask about the low beam HID but I'm almost positive it is covered as well under man. warranty (not sure about extended warranty).
gianttama
03-30-17 08:25 AM
OSURX350
RX - 3rd Gen (2010-2015)
12-26-16 04:03 PM
SethP
RX - 1st Gen (1999-2003)
09-15-12 11:02 AM
WinesRus2
ES - 5th Gen (2007-2012)
06-22-08 05:50 PM
darksparkz
Lighting
07-13-06 09:46 PM
Quick Reply: Replacement low beam light bulb
