99RX300 Transmission won't come out of PARK
10th Gear
Started car this morning & leaver moves freely from park but not selecting any gears. Is this a transmission problem, electrical or cable?
How does the stick feel? If the amount of effort is less then it is the linkage.
As simple careful examination at the far end can tell you if it is the linkage.
Salim
Salim
samasaurus (01-15-17)
10th Gear
Hi, Thanks to the post by Brcobrem on the 24th April 2015. I removed the "U" shaped plastic wood-grain console trim & could immediately see that the black plastic/nylon OEM bushing was gone & the transmission shift cable's end hoop/ring, was off the end of the shift lever's shaft. I used a piece of looped hat elastic to hold the cable in place & was able to drive to the mechanics for repair. So impressed & grateful for the information that is shared on this forum saved me grief, time & the cost of a tow truck.
That thread is over here:
https://www.clublexus.com/forums/rx-...t-lever-2.html
Regards . . .
Lavrishevo
10-20-13 02:38 PM
