Heater Core Replacement
Old 06-01-16, 02:57 PM
prgrisham
prgrisham's Avatar
Default Heater Core Replacement
Anyone out there got a step by step or know of a link to a video on how to remove/replace my heater core? it's a 2001 RX 300.
My servo kicked the bucket, and in getting it out, I put too much stress on the heater core line and it started leaking. Wonderful....
Thanks,
Patrick
Old 06-02-16, 02:11 PM
prgrisham
prgrisham's Avatar
Anyone? I looked under the dash an in the engine compartment... Looks very tight...
Curious what anyone would think of splicing in, instead of running the entire heater core and piping, just cut the pipes right around where the actuator is. splice together with hose and hose clamps.
I think it would be a lot less invasive, and much less risk of screwing something else up.
-Patrick
Old 06-02-16, 03:53 PM
carguy07
carguy07's Avatar
Splicing would be plan A for me. Very low risk and would save a ton of time and money.
Old 06-02-16, 03:54 PM
carguy07
carguy07's Avatar
Where did it break?
Old 06-02-16, 08:31 PM
prgrisham
prgrisham's Avatar
Originally Posted by carguy07
Where did it break?
Where the line attaches to the actual core.
Old 06-08-16, 04:13 PM
prgrisham
prgrisham's Avatar
No leaks after 100 mile burn in.
I initially used 5/8 line, it was tight, too tight, I was having to stress on the same pipes I had bent previously and now was replacing, so I went with 3/4, and I used clamps in the middle to minimize the hose pinching from the bend
Actuator also replaced for 45$ for a used one. Works perfect. Wife has heat again.
Old 06-08-16, 05:01 PM
sktn77a
sktn77a's Avatar
Nice job; worth an sticky, maybe.
Old 06-08-16, 05:15 PM
fastnoypi
fastnoypi's Avatar
nice fix, if you end up with the clamps cutting into the hose, consider using a Unicoil
Old 06-08-16, 09:12 PM
carguy07
carguy07's Avatar
Nice!
Sparkie350
12-30-17 11:44 PM
xspsi6
Performance & Maintenance
10-29-12 08:58 AM
Justin727
05-08-12 09:46 AM
v-empire
SC- 1st Gen (1992-2000)
17
01-29-10 02:39 AM
SC300_704
07-26-07 02:25 PM
Quick Reply: Heater Core Replacement
