RX 300 Back Pillar
Old 03-28-16, 03:38 PM
b2884987
b2884987's Avatar
Default RX 300 Back Pillar
How do I remove this back pillar?
Old 03-30-16, 08:20 AM
JDJackson
JDJackson's Avatar
Are you referring to the plastic or the full-on piller? If you are indeed referring to the piller, then I would say "Only if you are now making the RX a convertible!", as that is a structural piece for the roof.
Old 03-30-16, 10:04 AM
salimshah
salimshah's Avatar
Received 1,008 Likes on 911 Posts
The question is about interior trim piece
Salim
Old 03-30-16, 01:30 PM
cotis
cotis's Avatar
It's looks like you already have the rear cover mounts removed. The panel is snapped to the body frame with metal clips. You just need to pry it off, I would suggest a long thin pry bar to get under the panel and near the clip attachment points.
Old 03-30-16, 01:39 PM
b2884987
b2884987's Avatar
I'm trying to replace the glass, do I remove this panel?
Old 03-30-16, 03:27 PM
sktn77a
sktn77a's Avatar
I had to partially remove this panel to change the antenna. If I recall correctly, you must remove to top and bottom plastic trim pieces at the hatch opening and the floor cover first.
Old 03-31-16, 09:36 AM
cotis
cotis's Avatar
Look at this forum post, it has a picture with the side panel removed. Doesn't look like the window is held in from the inside, although I am not positive.
https://www.clublexus.com/forums/rx-...-module-2.html
spanlite
RX - 4th Gen (2016-2022)
05-07-19 10:08 PM
CharlieH
05-04-14 01:44 PM
spacecraft
05-30-13 05:15 PM
fancyjean
Maintenance
12-16-10 01:35 PM
GoodRevs
06-12-10 08:42 PM
Quick Reply: RX 300 Back Pillar
