crankshaft pulley
Old 03-10-16, 01:58 AM
lexrally
lexrally's Avatar
Default crankshaft pulley
Hi Forum
Had my RX300 inspected today. They said I should get the crankshaft pulley replaced
as there is a squeaking noise coming from it.
Is the crankshaft pulley something that can cause a catastrophic failure if it fails
(ie timing belt or other belts)? Does that thing EVER fail? Never heard of that happening.
Thanks!
Old 03-10-16, 02:53 AM
JAB
JAB's Avatar
Inspected by who? If something is 'squeaking' it is most likely either the alternator or one of the idler pulley bearings or the water pump.
Old 03-10-16, 06:12 AM
salimshah
Forum Moderator
salimshah's Avatar
Received 1,103 Likes on 992 Posts
Yes, crank shaft pulley can develop crack and can fall apart. I would not run the engine till it is replaced. The pulley can pack lot of rotational energy and can cause immense damage.
JAB's concern about proper diagnostics are well founded too.
Salim
Jkappel84
04-29-23 07:48 PM
synrgy350
04-22-16 04:11 PM
Ideal1267
12-14-05 03:07 AM
brit_lex
12-02-04 12:32 AM
lexlyf
SC- 1st Gen (1992-2000)
07-04-01 02:17 PM
Quick Reply: crankshaft pulley
