P0171 Smoke testing
Old 10-29-13, 09:29 PM
Rummat81
Rummat81's Avatar
Default P0171 Smoke testing
Hello Everyone,
i just bougght a 99 rx300. been hunting the P0171 code.
I smoke tested for leaks and had has smoke coming out of the accelerator cable linkage. i.e. where the shaft for the TPS passes through the throttle body and connects to the cable linkage springs.
Could there be a seal that has deteriorated.
I have attached a pic with the yellow pointer towards the area the smoke is coming from.
BTew, these are not my photos, i borrowed off the forum.
Attached Thumbnails P0171 Smoke testing-accel_cord2.jpg   P0171 Smoke testing-img_2079.jpg
Old 10-30-13, 05:27 AM
Baetke
Baetke's Avatar
What kind of equipment did you use to perform the smoke test? I would like to perform this test on my car too.
Old 10-30-13, 06:55 AM
Z07
Z07's Avatar
From page 1587 of the FSM. I hope it helps but I see no seals/gaskets/washers etc. Do the throttle plates(butterfly valves) rotate smoothly?
Old 10-30-13, 07:35 AM
Rummat81
Rummat81's Avatar
@Baetke: i used the following method.
http://www.r3vlimited.com/board/show....php?p=3530331
@Z07: Is that diagram related to rx300 throttle body, i do not see two butterflies side by side.
Secondly i am not sure if we have a motor mechanism in the Throttle body. Can you please recheck the diagram and application.
The throttle moves smoothly throughout the range.
In Boosted applications, i have seen people replacing seals on the throttle shaft.
There has to some sort of sealing mechanism between the shaft and the housing.
Old 10-30-13, 10:43 AM
Baetke
Baetke's Avatar
Did you forget to include a link?.
Old 10-30-13, 11:31 AM
Rummat81
Rummat81's Avatar
updated:
Old 10-30-13, 04:28 PM
carguy07
carguy07's Avatar
I would think a small amount of smoke would come out there and not be an issue. Maybe try shooting carb cleaner at it when it is running and see if it sucks enough in to make the idle change.
Old 10-30-13, 04:36 PM
salimshah
salimshah's Avatar
I like the carb cleaner way to test for vacuum leaks.
Salim
Old 03-04-14, 02:18 PM
Rummat81
Rummat81's Avatar
Just to close it off. It was the old O2 sensors all the way.
Two new upstream sensors, and No codes anymore.
sagarx
12-03-20 03:50 PM
Dukenukemx
09-25-19 04:51 PM
rac74
01-12-17 11:04 AM
Cp2295
11-26-16 12:24 AM
LEXMICK
10-30-09 01:34 AM
Quick Reply: P0171 Smoke testing
