Steering wheel Squeak/Squeal!
Old 05-28-05, 04:36 PM
almondm
almondm's Avatar
Exclamation Steering wheel Squeak/Squeal!
Please someone make my steering wheel stop squealing when I turn - what is going on? '99 RX 300 - too nice of a car for this -
Old 05-30-05, 06:32 PM
Philly RX
Philly RX's Avatar
I am having the same problem with my 2002Rx but its only noticed at low speeds 15-25m
Old 06-01-05, 04:49 PM
parula
parula's Avatar
Mine did it recently too, but then it stopped. Have no idea what causes it. I'll check for TSBs.
Old 06-09-05, 07:06 PM
Fern
Fern's Avatar
Default steering wheel squeek
dealer lubricated something behind wheel and noise lessened..
No charge..
I would try wd40 behind the wheel in the area where the wheel pivots.
Cheers,
Fern
Old 06-29-05, 07:51 PM
Chris Hill
Chris Hill's Avatar
I had the same problem -- It was an easy fix for me.
Get a flashlight and follow the steering column down to where it meets the firewall. Surrounding the shaft is a rubber boot that circles the steering shaft.
This boot on my Rx300 was completely dry and sounded like a siamese cat whenever I turned the wheel -- especially on cold mornings. Everyone who entered the car for the first time commented on the sound, and it drove me nuts.
All I did was put a little oil around the boot and the problem was solved.
It worked for me -- hopefully it will work for you. Good luck.
Old 07-18-13, 03:10 PM
bachree
bachree's Avatar
worked great for me too with silicone spray lubricant.
Old 08-09-13, 11:21 PM
slanzet
slanzet's Avatar
Default Same problem with noisy steering wheel.
Will try to lubricate. Thanks
Old 08-10-13, 04:22 AM
MtnDweller
MtnDweller's Avatar
Need to do this as well. Squeaks every now and then.
Tina
Old 08-12-13, 08:19 AM
bachree
bachree's Avatar
The squeak started again after two weeks and now the effect of lube is completely gone. I need to lube it again or try a different kind of lube which will last longer.
mark98ls40
06-17-09 12:31 PM
donnie boy
14
01-22-09 11:17 AM
dzell81
03-27-06 07:05 AM
mink92890
03-13-06 03:12 PM
Quick Reply: Steering wheel Squeak/Squeal!
