1999 RX 300 Limp mode
Old 09-24-12, 02:47 PM
jsaake
jsaake's Avatar
Default 1999 RX 300 Limp mode
My car has 92,000 miles and I just had the timing belt replaced. On a drive from SF to LA, the car performed flawlessly for the first 4 hours. After filling the gas tank, and getting back onto the freeway, the car would not shift out of second gear. Warning lights did not come on. After resting overnight, the car ran properly for 35 minutes and then, would not shift out of second gear. Again, no warning lights. At one point, there was a loud sound as the car switched from first to second gear.
The Lexus dealer is puzzled but the friendly neighborhood mechanic said that the car is in "limp mode". I understand that this occurs when the engine CPU receives conflicting information and limits power to prevent possible damage.
Can anyone please verify if this is the case and if so, is there an easy fix?
Thank you in advance
Old 09-24-12, 04:50 PM
salimshah
salimshah's Avatar
There can be multiple reasons to get into limp mode, or even problem in the xmission (including the shift lever) which can lock you in a gear.
First order of business would be to get the diagnosis done. I would suggest taking the RX to the dealership. They should have the right equipment to diagnose.
Please check if your CEL bulb is working and I would suggest connecting up to the code reader.
Salim
roumieh200
12-20-10 02:35 PM
polo1215
06-26-08 12:58 AM
andrewa
09-08-07 01:09 PM
man8959
GX - 1st Gen (2004-2009)
02-11-07 09:09 AM
Quick Reply: 1999 RX 300 Limp mode
