Fuel Door Problem - need help
Ok i think i figured it out i believe someone has pryed the fuel door ooen and busted the nipple off that latches to keep door closed.Can that be replaced without replacing cable and how do you change it?
Post a picture.
At times you can epoxy something to the inside of the lid/door
Salim
I read the problem description different than do you, Salim. I think he is missing the part that protrudes and recedes in response to the lever in the passenger compartment.
I misunderstood the problem before as well ...
Can we get a better description...
Is it the pin that moves in and out as you pull the lever?
Or
The catch on the door (which receives the pin)?
Or
It is an adjustment ... relative to each other the pin does not extend enough to get to he catch or the catch is broken or not close enough to receive the pin.?
Salim
Or
Or
Salim
My 1999 just had this exact problem last night. I will tell you this - if you are by yourself, it is hard as poop to try to pull up on the fuel filler door latch inside the car and have something wedged into the fuel filler door to make it open.. I first tried my plastic grocery coded key fobs and each time it worked - but 3 times the door opened, the keys fell out - the door shut and locked back.. and I was left there not accomplishing anything.
Next I asked a fellow gas getter to pull up on the latch while I caught the door. Then I saw the little plastic fragments inside the fuel door assembly which proved something did in fact break.
The little spring was what broke loose. I have the spring and was able after about 10 mins to hold it into place while I quickly got the door shut. So I know it is in place but will fall straight out the next time I open the fuel filler door.
I plan to glue the piece back into place using JBWeld.. unless the $5.00 part shows me that it is in fact a true fix.
Thanks for posting this.. you are not the only one. Brian in Branson, MO
LA4Mead (06-18-18)
my spring just fell out, and I luckily found it on the ground. How does it attach though??
edit: I found some photos online. without spring:
with spring:
I had to glue mine in place; hope it holds....
with spring:
LA4Mead (06-18-18)
djeddieo:
Observe the picture you posted. It has a plastic base with a pin (raised) portion. If that piece is attached to the lid, then all you need to do is slide the metal push-off and it will click in place. If the plastic piece is missing then you have to secure a replacement to the door. Not sure what pieces are sold by Lexus.
Salim
Salim
To DJEddie or anyone else who repaired:
How did you fix yours?
How has yours held up?
Thanks for your post!
Hi OzrkFisher Did your fuel filler door spring fix work out?
The tensioner slides in the slot and clicks into the lock position.
No glue is required.
Salim
Salim
