Need help 99 rx300 awd check engine light on codes po300,po301,po325,po330
Old 04-01-11, 11:46 AM
ZeekGS300
ZeekGS300's Avatar
Default Need help 99 rx300 awd check engine light on codes po300,po301,po325,po330
hey guys i have a 1999 rx300 awd i recently picked up last month and i tried to smog it today 4/1 but it failed smog due to the CEL po300,301,325,330 i need help on how to fix it and i noticed my rx300 drives kind of draggy and it takes a lot of gas. thanks
Old 04-01-11, 04:37 PM
salimshah
salimshah's Avatar
First, clear all codes and then on first onset of cel get a read.
Salim
Old 04-02-11, 01:27 PM
sktn77a
sktn77a's Avatar
Is the car running rough? If it is, it's probably a bad cylinder 1 coil. Clear the codes and see what comes back.
Old 04-12-11, 05:36 AM
ZeekGS300
ZeekGS300's Avatar
I replaced all the coils and then the cel came back on then the cel started blinking.. I have't got to check the cel yet but i will later on today
Old 11-26-11, 01:45 PM
MarkG2000
MarkG2000's Avatar
Default Help
Also just got a PO 300 but I also have a 1305.
What's the ussue...s
thanks guys
Old 11-27-11, 06:13 AM
Lexmex
Super Moderator
Lexmex's Avatar
thanks guys
On the front bank (underneath the engine cover), check the ignition coil furthest to the left, known as cylinder #2. Switch the coils with another one on the same front group of 3 and see if you get a different code than P1305. It can be the coil itself, but it can be the electrical connection on the coil in this particular case.
Old 11-28-11, 07:21 AM
MarkG2000
MarkG2000's Avatar
ohhhh man...Didn't get the reply so I switched out the #5
with the 2....now I get 1320 and after a bit more research
that's the #5...yes?
wasn't so bad getting back there. I took the 5 on 1305 to
mean #5...lol
So in essence...the 1305 being #2 coil...was the bad one.
This is the 3rd coil I have to change this year.
Old 11-28-11, 07:26 AM
Lexmex
Super Moderator
Lexmex's Avatar
mean #5...lol
I've only had to replace one and that was because I put too much carb cleaner into the throttle body one time. I actually had to modify a coil for a Camry at Toyota (was in Mexico at the time) to be able to work with the RX300 until I could get a new one (no Lexus there until at least 2012).
Jacklalane
39
06-28-15 03:37 AM
Leines
18
03-20-12 02:46 PM
iamgg63
12-06-10 08:12 PM
lillexrx
12
11-28-09 11:30 PM
speedtoys
26
01-27-06 12:41 PM
Quick Reply: Need help 99 rx300 awd check engine light on codes po300,po301,po325,po330
