Key remote lock/unlock do not trigger front and back lights.
Old 10-06-09, 11:14 AM
trips1
trips1's Avatar
Unhappy Key remote lock/unlock do not trigger front and back lights.
So i got my O2 sensors checked using diagnostic monitor at an independent shop. And after getting that done i am seeing that my front and back corner yellow lights do not blink when i lock/unlock using the button on my key remote.
I would appreciate if anyone has any clue what may have gone wrong. I wanted to check first on this very helpful forum before calling the mechanic shop.
Old 10-06-09, 12:05 PM
bob2200
bob2200's Avatar
I think the first thing to try is to disconnect the car battery for maybe 10 minutes, reconnect it, and then see what happens.
Old 10-06-09, 01:10 PM
wvuguy
wvuguy's Avatar
Front and back lights have not blinked in my 99 rx300 on remote lock/unlock since the day I got it. Later on I found out it was because front passenger lock was not responding to the lock/unlock signal. The lock was always staying in unlocked position. Once I put it in lock position, the lights started blinking. I have seen some posts here about replacing the lock actuator to fix the problem. So far I havent really gotton a chance and this problem doesnt really bother me. You might wanna check and make sure all your lock are responding to the remote signal.
Old 10-06-09, 01:29 PM
SC300Star
SC300Star's Avatar
Originally Posted by wvuguy
...I found out it was because front passenger lock was not responding to the lock/unlock signal. The lock was always staying in unlocked position. Once I put it in lock position, the lights started blinking...
Same thing happened on my Wife's '99 RX - had to replace the door lock actuator...
Old 10-06-09, 02:03 PM
trips1
trips1's Avatar
Default Thanks....
Thanks to everyone..... Yes i found that my driver side lock is not responding to key lock/unlock signal. It always remain in unlocked position...... Once i lock it manually the light flashes...
I am just wondering why everything bad has started showing up with a week of my hitting 100K on my odometer .....
So i need to get the lock actuator to fix this issue... Any pointers on the price of labor (Toyota dealer or independent) and part would help..... or is it a simple DIY...
Old 10-06-09, 02:13 PM
trips1
trips1's Avatar
Found the DIY in the DIY list :-)
Has anyone got this done at independent mechanic/Toyota dealership? Price?
swat1727
03-27-24 10:31 AM
Power6
05-06-12 02:32 PM
eskae3
08-17-11 02:13 PM
wbmx1981
09-27-09 11:57 PM
palaka
09-24-08 11:55 PM
Quick Reply: Key remote lock/unlock do not trigger front and back lights.
