MY 00RX 300 vibrates at 65 MPH
Old 01-22-08, 04:01 PM
tlegend
tlegend's Avatar
Exclamation MY 00RX 300 vibrates at 65 MPH
when i purchased my car it came with 20" wheels and tires and at 60+ heavy vibration.. So i purchased stock 16" and now i have little vibration still.
The 16" i had them balance the wheels + tires so i know its not the 16" wheels
Could it be my alignment?
any help is appreciated.
THX
Old 01-22-08, 04:07 PM
greyBLITZ
greyBLITZ's Avatar
A very common problem is the actual harmonics of the vehicle itself. Unfortunately I'm not sure what you can do about it, but perhaps the pros might have some suggestions.
Old 01-22-08, 04:22 PM
salimshah
salimshah's Avatar
Rim size has almost nothing to do with it ... other than larger rims require more delicate balancing. I have heard that Hunter machine gives better results.
Salim
Old 01-22-08, 04:38 PM
tlegend
tlegend's Avatar
Mr. Salim G
What can i do to try to improve it, basically the steering wheel vibrates going beyond 65MPH
Old 01-22-08, 08:04 PM
salimshah
salimshah's Avatar
This is again one of controversial issue. I am of the opinion that it is due to lack of proper balancing. Some say that lack of alignment causes shakes (my view is only if the things are loose).
I would suggest take the RX back to the shop who did the balance and if needed take the tech for a test drive.
Salim
Old 01-23-08, 06:18 AM
lexus114
lexus114's Avatar
If your wheels are not torqed properly/unevenly it will do that (I have first hand experience on this) try removing each wheel,installing nice and evenly,dont over tighten them, and see if that was your problem.In other words,If they started tightening your wheels by torqing down on the first lug nut,etc.then your wheel is installed unevenly.
Old 01-23-08, 10:00 AM
AlexusAnja
AlexusAnja's Avatar
Misalignment usually causes straying and travel of the steering. If the vibration is from the wheels and you feel it in steering wheels, I'd say it's more likely the balance. Make sure you get all four wheels re-balanced and tell the shop that did it the problem.
Old 01-30-08, 10:57 AM
tlegend
tlegend's Avatar
i went to get my tires rebalanced today, and they told me tires were not off balance..
should i go in for a 4 wheel alignment???
Old 01-30-08, 11:51 AM
salimshah
salimshah's Avatar
Did you take the tech for a ride afterwards?
Was any work done on the drive half shafts/rotors etc that can make them off rotational balance?
Salim
Old 01-30-08, 12:55 PM
lexus114
lexus114's Avatar
If your iner cv joint(tripod)is going bad,it will do what you describe,especially if you are on the gas.
dunahoo
Suspension and Brakes
06-17-08 05:59 PM
2KGS400
04-26-04 05:35 PM
kdubb
07-23-03 04:13 PM
CoreY2K1
Wheels, Tires & Brakes Forum
02-17-03 03:59 PM
Swing913
21
09-08-02 12:16 AM
Quick Reply: MY 00RX 300 vibrates at 65 MPH
