What is the max width wheels setup for the RC Fsport
Old 04-26-15, 02:10 AM
vxlyf3
vxlyf3's Avatar
Default What is the max width wheels setup for the RC Fsport
Hi guys, Im really tempted to do a setup of 19x9.5 and 19x11 (Both +35 to +40) any chance fitment will be good? Also what is the max setup that you guys with aftermarket wheels are running.
Old 04-26-15, 07:03 AM
FrogBreath
FrogBreath's Avatar
Should be fine as long as you get the right tire size, dial in suspension and camber. Ill be running 20x10.5 +45 in front and 20x10.5 +25 rear which will be similar to your set up. I'm on air though.
Old 04-27-15, 11:22 AM
vxlyf3
vxlyf3's Avatar
What wheels will you be running frogbreath?
Old 04-28-15, 07:43 AM
juvi22003
juvi22003's Avatar
I can see those fitting fine, not like you will be running low offsets....just gotta pick your tire size wisely
Old 05-12-15, 03:36 PM
vxlyf3
vxlyf3's Avatar
What about 10.5 +22 all around?
Old 05-13-15, 03:15 AM
FrogBreath
FrogBreath's Avatar
10.5 +22 will be very very aggressive in front. Probably have to run camber and 245/30 tire. I would say a 10.5 + 40 would be Max you would want to go.
Old 05-13-15, 08:51 AM
juvi22003
juvi22003's Avatar
10.5+22 will be very aggressive for the front, for the rear i see them fitting with stretched tires 245 35 and probably need to roll your fenders
Jwconeil
IS F (2008-2014)
23
02-26-22 07:14 AM
ksan
11-14-15 07:42 AM
skinnie
08-22-14 08:23 PM
RTIS250
08-09-08 04:57 PM
skpark70
Wheels, Tires & Brakes Forum
05-23-07 10:53 PM
Quick Reply: What is the max width wheels setup for the RC Fsport
