RC-F Mod wishlist, What should FIGS make?
Hi guys I thought I should post and get some demand on things that RC-F owners will be looking for to customize their vehicle experience. We have our list of identified products that we are working on the final stages of release but wanted to add to fuel to the fire. We will focus on performance and weight reduction.
Current plans are:
- Coilover conversion for the rear with adjustable lower control arms similar to what we have done on our 25hr sponsored 3IS race car. (Weight reduction/performance)
- Carbon ceramic brake upgrade using factory Brembo calipers.(weight reduction)
- Exhaust and header offerings via PPE. (Performance increase)
- Silicone intake from HPS.(Performance increase)
- Poly bushing replacements for the suspension.(Handling improvement)
- Verification of our differential mount bushings. (Performance)
Feel free to add to this thread and you think of things or mention things we might have overlooked. We are a small staff so anything to help our focus will just mean getting the products you want first. We have not slated an cosmetic items for the car just yet but we can certainly work on something if there is enough demand.
Mike
Current plans are:
Mike
__________________
Redefining Lexus Aftermarket Parts Since 2001
-- We are your Lexus suspension experts--
BCR - KW - PENSKE - OHLINS - HKS - GREDDY - STANCEPARTS
Links - Arms - SuperPro Poly Bushings - Solid Bearing Conversions - Motor Mounts
RB BBK's and 2P Rotors, G-Loc pads, Radium Fuel Systems
Custom Fabrication Design and Machining - Industrial 3D Printing - Laser Cutting
2018 USTCC Sportsman Class Champions - 2018 NASA ST5 National Champions
absolutely, and these should already be a bolt on.
__________________
I would ditch the coilover thing since this car have different suspension level so I wouldn't mess with it
Things I really hope to see are
Two piece light weight brake rotors for front and rear (unsprung rotation weight) very important!
carbon fiber drive shaft (unsprung rotation weight) very important!
Lighter weight brake calipers using one piece forged alloy.
that's all I have in my mind now. but the first two wish list are very important to me.
-Weight reduction as a function of eliminating the pocketed spring and allowing a reduced winding and tighter coupling to the damper by moving it outboard. This will also allow us to damp more effectively and alter spring rates for different performance setups. As soon as power is added to the platform and wider tires the suspension demands will be higher. Despite the factory setup being a much better starting point than in the past, they are still constrained by cost and the selection of a several modes modes of damping. We would favor a higher performance dual flow mono-tube damper that will achieve similar results but provide faster response. One issue I have always taken with adaptive damping is that is uses the past/present to predict the future. Its good for an offset but ideally you want to be in the most responsive position to meet what road conditions are ahead regardless of where you have been. We will be studying the response and performance of the system and address things accordingly.
-Adjustment, the lower control arm with a pocketed spring will restrict adjustment to just the upper links, we would always like to add flexibility in addition to rigidity to the location in the suspension controlling weight transfer and contact patch. The RC-F does use a cast aluminum arm so the weight will be pretty good against strength, but there is always room for improvement at the margin and weight reduction on this car is going to be a sum of small parts.
We may find that this is unnecessary, but we will certainly be doing for the RC and 3IS platforms, so an adaptation to the F is at least on the road map for evaluation.
__________________
Yeah you got that right. I am 5'11" and my helmet has to be tilted as well. We can do it if demand is there.
__________________
Also after driving the car this past week I am certain we can make improvements to the suspension.
__________________
ha, yeah, don't wanna go there.
__________________
