Audio Level Via Bluetooth Seems Low?
I have the standard audio system in my RC-F and it seems that, for whatever reason, the audio level from my iPhone via Bluetooth is down. I can turn it up to 62 (max) and the sound is not overly loud and I know it used to be higher riding no more than a 50 setting when it was bordering on too loud for me. The alert tones from the phone, etc. and the radio volume seem as loud as ever. I don't have any sort of gain or volume levelling on the iPhone or iTunes as far as I can determine.
Although I can't find it, is there a "per source" level setting in the audio package that I may have accidentally set incorrectly too low? Any other suggestions?
Thanks much!
Thanks much!
sometimes I have to adjust the volume back up manually on my phone and it will give me a message about dangerous levels, blah, blah. Once I turn the volume up on the phone it allows higher volume through the speakers. It may be that simple for you as well, hth
FWIW they both sound like crap, the best option is the 3.5mm headphone jack, however you lose the ability to control the phone through the car.
I use Bluetooth because I got tired of dealing with the unit and it's inability to allow Bluetooth and USB simultaneously. The Lexus Enform app will not work over wired connection, it is just easier to have the phone connected to the power port for charging and use the Bluetooth for music.
works for music on the iPhone, does not work when streaming Pandora.
