Boost leake? 2JZ-GTE
Old 06-22-16, 02:47 AM
Ali2GS300
Ali2GS300's Avatar
Default Boost leake? 2JZ-GTE
Hi CL,
i'm running stock sequential. I have a boost gauge and it was boosting to around 10-11 psi. yesterday i noticed that it only boost Up to 7 psi then it starts dropping to 5-4 psi. I went ahead to do a smokey leak test. I caped everything from the turbo inlet to the turbo outlet to test the turbo manifold by itself. (picture below). I can hear a little hissing but i don't see the smoke coming from anywhere
i opened the oil cap and all the smoke came out. is this normal? i understand the air goes to the crankcase through the PCV valve but i already capped the pcv on the passenger side ( the turbo side) so i can only test the turbos and the turbos manifolds or am i wrong?
could it be blown turbo oil seals?
1JZSc300
SC- 1st Gen (1992-2000)
10-04-10 12:04 PM
SC51
Performance & Maintenance
12
03-27-10 12:28 PM
fordsvtmfl
Performance
17
10-23-08 06:01 PM
lex1997
05-15-06 06:45 PM
Quick Reply: Boost leake? 2JZ-GTE
