DIY midpipe swap advice
Old 05-01-16, 08:57 AM
murfman89
murfman89's Avatar
Default DIY midpipe swap advice
I have an IS250 2012 and need to swap out my midpipe and wanted to do this at home. I have (4) 3-ton jack stands and a hydraulic jack.
So, can I do this myself and which end is best to lift up if I plan to only lift one end? Front, back or do both at separate times? I was thinking front end.
And is this ok to do this myself?
I am reinstalling my OEM midpipe and removing the Invidia midpipe, too raspy, too much drone.
Thanks,
Mike
Old 05-01-16, 12:33 PM
Gville350
Gville350's Avatar
I personally start by raising the front via the pinch jam jack points, then the rear via the carrier.
Yes, assuming you have a few wrenches.
Old 05-02-16, 08:05 PM
604GSE21
604GSE21's Avatar
i just jack the front on my is350 and i had enough space to pull the whole mid pipe out...
Old 05-02-16, 08:11 PM
kumquatism
kumquatism's Avatar
I did the whole thing by myself. I just put the whole car on jack stands. Makes it easy if you have a bit of room to work with under there, especially to remove the o2 sensors.
Old 05-03-16, 09:22 PM
MWIS350
MWIS350's Avatar
Jack up driver side front. That the only one you need. I also have invidia midepipe with Tanabe exhaust it took about 2 week for the noise to quite down, and relearn. First week was load and annoying.
Old 05-03-16, 09:25 PM
murfman89
murfman89's Avatar
Thanks, but I had it taken out. It was just too loud and the drone too loud to the point it bothered. The Magnaflows sound good with very little drone, mostly just engine noise if that. That sounds good at start up too. Sold the pipe too.
- Mike
Old 05-03-16, 10:26 PM
MWIS350
MWIS350's Avatar
For me I like it. I think it help with Tanabe. They're the quite muffler in market.
Lveyolfe
06-24-17 10:37 AM
murfman89
Performance
12
05-06-16 06:31 PM
Heavyhitta
Performance
66
04-28-16 10:51 AM
brociouz
09-29-12 04:16 PM
brociouz
Performance
06-25-10 11:54 PM
Quick Reply: DIY midpipe swap advice
