turboing the na block
Old 10-09-14, 12:43 PM
stephan47
stephan47's Avatar
Default turboing the na block
so i just a have a couple questions on turboing the ge block so what would i need to run about 15 pounds of boost aside from the controller the turbo kit im talking about like engine managers what what not and what do i do about the cats?? i want both cats still because i need to pass emission and help would be appreciated.
Old 10-22-14, 07:49 AM
derishi
derishi's Avatar
You have a ton of research to do my friend. Check out the my.is forums as there are a million threads on what is needed for certain power goals
Old 11-25-14, 10:52 AM
George88
George88's Avatar
what kit are you going to be using ?also you will have to relocate abs
Old 12-01-14, 01:28 PM
derishi
derishi's Avatar
Not entirely true as there are some options that won't require the ABS relocation, but most applications will have you move it further back
Old 12-10-14, 05:18 AM
mitsuguy
Maintenance Moderator
mitsuguy's Avatar
You can't have both cats with a single turbo.
Even though you may be able to get the car to pass the plug in obd2 test, it will never pass a real visual inspection. Some dummy might not know and pass it, or might overlook it and pass it, but it would never pass 100% properly.
evanrigs
Build Threads
05-08-19 07:39 PM
Black1129
IS - 1st Gen (2001-2005)
09-21-15 09:42 PM
Thrustn
Performance & Maintenance
08-06-15 10:31 PM
yell0w
04-28-13 12:24 PM
sj408
04-03-09 11:19 AM
Quick Reply: turboing the na block
