What presets on the ECU are you talking about? I don't think you know what an ECU is based on your question....are you talking about the settings in your Nav system?
You will most probably lose your settings on the stereo/nav. The ecu controls the engine and should also reset but you wont notice anything different there.
Radio stations, Nav system, Bluetooth, everything that I have changed since the day I bought the car.
How about just taking out the two (I believe) ECU fuses instead of disconnecting the battery?
I believe when you are disconnecting the battery (power), you are doing a hard reset. Most likely, the electronics in the car will go back to it's initial setup.
Surprisingly enough, you DONT lose a thing. I installed my intake and had the battery ( neg terminal ) off for about 15-30 mins. I got back in the car, everything was the same. The first time you turn the car over, it shuts off immediately. Then a "loading" screeen comes on, then you just crank over as you would. Hope this helps.
