View Poll Results: What kind of LSD do you have?
TRD LSD
24
21.62%
Supra (RMM) LSD
43
38.74%
Stock LSD
44
39.64%
Voters: 111. You may not vote on this poll
LSD: TRD, Supra, Stock
Old 02-15-07, 04:48 AM
  #31
Guru
Guru's Avatar
Carbonetic Carbon LSD here. THE best and still going strong over two years now. LOVE it. Best mod to the car other than the sway bars.
Old 05-15-07, 07:15 AM
  #32
Rock-a-Lex
Rock-a-Lex's Avatar
Installing my 3.76 Torsen (Supra) LSD, new supra half shafts, PI TC and tranny cooler very soon. Got quoted around $900 for all...does this quote seem too high???
Old 05-24-07, 10:51 PM
  #33
bighitbike
bighitbike's Avatar
Nope, seems pretty good actually
Old 05-25-07, 05:10 AM
  #34
Rock-a-Lex
Rock-a-Lex's Avatar
Thanks a lot Big...I'll still try to chew him down a little. LOL!
Old 06-01-07, 05:14 PM
  #35
David GS400
David GS400's Avatar
I have a stock LSD and it lays down two even patches of rubber when I'm on it, so now I'm confused what is stock. How is the TRD LSD different from the stock one?
Thanks in advance,
Originally Posted by GS430 GUY
LSD= Limited Slip Differential
The GS stock doesn't have a true LSD, it has an open differential. So power doesn't go to both wheels, only one, which is why power breaking and hammering the accelerator will not allow one to leave 2 patches of rubber on the road. I am not a technical genius on automobiles, but using the search engine will bring up a lot of info as the LSD has been discussed in detail a few times. I'm happy with my TRD LSD but I agree with LexCiting on it being an expensive mod, but worth it in the end IMO.
Old 06-01-07, 07:40 PM
  #36
IAGS400
IAGS400's Avatar
Thanks in advance,
If your rear end is stock, it isn't a LSD.
Originally Posted by jbrady
Something of note: open differentials DO IN FACT power both tires UNTIL one tire looses traction and then 100% of the torque goes to the one without traction. This is why one tire will spin.
Old 06-05-07, 03:03 PM
  #37
Cruizing
Cruizing's Avatar
Once the Torsen rear end is in is the VSC still functional at any time?
Old 06-05-07, 05:44 PM
  #38
3dog
3dog's Avatar
Smile Vsc
Yes it still works. Plus you can hit the button and turn it off if you want.
Don't do that in the rain cuz when the road is slick the VSC is your friend.
Ivan
3dog
Old 06-05-07, 05:48 PM
  #39
IAGS400
IAGS400's Avatar
Does the traction control and stability control that are within VSC work?
Old 06-05-07, 06:03 PM
  #40
3dog
3dog's Avatar
Default Lsd
Everything works
Old 06-08-07, 10:26 PM
  #41
David GS400
Is the RMM LSD essentially the same as the TRD LSD? They both have 3.76 gearing? What's the difference if any?
Old 06-09-07, 08:58 AM
  #42
bpc23
bpc23's Avatar
There's some question of interchangability of the Limited Slip Supra Diff Carrier with the stock Lexus Diff Carrier. In my post below, I detail the steps I took to complete the swap in my GS400 while retaining the stock Lexus differential gear ratio. It's basically a "take it apart, put it together" proposition. All the internal differential parts are interchangeable. https://www.clublexus.com/forums/sho...d.php?t=250495
Brian
Old 06-09-07, 06:32 PM
  #43
Rock-a-Lex
Rock-a-Lex's Avatar
From what I understand only the RMM and the Supra TT (torsen) LSD come with 3.76 gears (for quicker acceleration in the GS4xx NOT GS300). The TRD unit still utilizes the 3.23 gearing and is also an LSD. TRD is less expensive to buy but more expensive for the install.
Old 07-01-07, 09:05 AM
  #44
kilawatts
kilawatts's Avatar
Default Quick Question....
I have been offered to trade my stock GS400 3.26 Rear End for a 4.27 pumpkin with lsd from a NA MKIV supra. I am not certain why someone would want to make this trade seeing as my Rear End is not LSD, but not complaining seeing as I want an LSD.
My question is will this bolt up and perform well? I notice the majority is using the 3.76 LSD. Is 4.27 too high of a ratio for a GS400? I do not have a TC, but it will most likely be my next mod. Any advise would be greatly appreciated.
Old 11-16-07, 08:24 AM
  #45
slowdiver
slowdiver's Avatar
I used to have the 4.27 gears and loved them. I was on 20's though. If you search for "gear ratio research" under the performance section, you will see my thread about the different ratios and RPM levels.
I have a question for the guys with the TRD LSD....
I believe the TRD LSD is a mechanical cable type LSD and therefore does NOT have clutch plates which would mean there is no clutch plate "chatter" or noise on slow speed sharp turns like a clutch type LSD has (KAAZ).
Does the TRD have any chatter noise at all on slow speed sharp turns?
Quick Reply: LSD: TRD, Supra, Stock
