Power steering assist delete
Dude I do this right?
I plugged a fitting into the spot and capped the vacuum port but I'm wondering what I do with the other rubber hose
I am not following what you did, but it's been a month since I deleted my power steering so I can't recall exactly how it was. I tried it by totally deleting the a/c and power steering but this beast is too much to fight with manual steering so I am going to put it back. I had planned to just connect the 2 vacuum hoses since one goes to the the timing belt area under the cams and the other goes to the intake manifold, or at least that is the way I remembered it. Is there a 3rd line?
One vacuum line goes from intake manifold to the pressure house banjo bolt. the other goes into the timing cover. I was unsure if the way I deleted it was proper. It must seem so since at first it leaked but then after some teflon tape the leak stopped and the car feels more responsive with out the steering assist feature. I think I did this right.
I thought I read on one of the threads
6SOARER
Performance & Maintenance
02-23-20 09:04 PM
SC300_704
12-12-07 08:59 PM
