Power Steering Problem
Old 08-17-10, 02:48 PM
tryst
tryst's Avatar
Default Power Steering Problem
So I was driving from Dallas to Austin and I noticed my Undercarriage cover at the bottom of my car was scraping because it had some missing screws. I pulled over to take it off. And continued my driving. And I was driving fine until just an hr ago, it was really hard to steer my Lexus. I pulled over and look at the power steering fluid reservoir and it was empty, and I was concerned because it was full when I checked it at the beginning of the trip. Then I look at the bottom and noticed this.
Is that hose my power steering hose? It's leaking.
Here's another image of it, I think it leads to the power steering fluid reservoir
Here are my questions.
1) Is it expensive to replace a power steering hose.
2) Is it going to cause more damage if I drive without power steering?
3) Is that leak EVEN the power steering hose?
thank you all
Old 08-17-10, 02:55 PM
LexChamp
LexChamp's Avatar
Have at it:
https://www.clublexus.com/forums/ls4...ing-bible.html
Old 08-17-10, 09:25 PM
AzHotLS
AzHotLS's Avatar
If that is your power steering low pressure return hose, it's a hack job repair as it normally is made up of sections of metal tubing and short sections of hose.
Short of making it right, park the car, cut off a short piece of it and go buy a length of transmission cooler hose to replace what you have.
Old 08-18-10, 06:32 AM
billydpowe
billydpowe's Avatar
Good Grief man, a new hose is only $80. and is simple to put on, I replaced mine (97) a year ago, off ebay, abcmarts - seller, and it was a perfect fit.....
why all the problems???
Old 08-18-10, 07:18 AM
AzHotLS
AzHotLS's Avatar
Or you can do as billy says and to it the right way!!
Deegee
Suspension and Brakes
05-09-18 02:29 PM
moneysc400
Performance & Maintenance
04-23-14 07:34 PM
Dougspeed
01-13-08 07:16 PM
SC300_704
12-12-07 08:59 PM
Quick Reply: Power Steering Problem
