Bubbling water sound behind my dash board
When the weather isn't below freezing I drive my car and hear this running water noise. It seems to be coming from behind the passenger side of the dash board. I don't know if it's trapped condensation or what. I was just curious if this has happened to anyone else and what the problem could be. My greatest fear is rust.
The only time you hear coolant flowing is when there are air bubbles in it. If you can hear a bubbling sound behind the dash that likely indicates a leak in the cooling system or a blown head gasket. These things can start VERY slowly and take months, sometimes even a year, to develop. Now, sometimes you can hear the actual flow of coolant but it is a steady hum, not a gurgling/bubbling sound, the cooling system is a closed system, the only way you get bubbling is when air has displaced coolant.
JohnnyGee (02-28-23)
You might have some air trapped in the heater core. I suggest parking you car on a steep incline (hood facing up).Let the car cool down. Take the radiator cap off, and let the car warm up (with heat ON) until coolant starts to run out of the radiator neck. Turn off car. Then put rad cap on, and drive off. Keep adding coolant to the overflow tank until it's above the hot line when running.
soloist3 - is on the right track... Did you recently do anything with the cooling system .... Oil looks clean and at the right level... Heater core is the direction I would be looking
Jay21
11-08-15 09:02 PM
e-man
02-08-10 09:50 PM
