gs300 transmission in a sc400
Old 11-25-14, 04:56 PM
vegaswins
vegaswins's Avatar
Default gs300 transmission in a sc400
Hi,i recently swapped a gs300 tranny in my Lexus sc400,was told everything was plug and play,well after i got the tranny bolted in i found out,that was not true.Now im slapping my self in the face for not making sure it was 100% true.
So now im asking yall how i can fix this do not want to get a new tranny,now il explain my problems so after i figured out that the solenoid plug and whatever the thing is connected to the shifter shaft and the i believe to be speed sensor were all different plugs
so for the shifter shaft i swapped over the old one with no problems-solved
i swapped over the solenoid plug but the new tranny has 5,and the old one only had 4,so now no od
and the speedometer sensor has no plug at all on the new tranny,
so now my question is what can i do?
here is the closest pic i could find on the internet the small box looking solenoid is the one im missing the plug for
any help is very appreciated-sry for not being the best at explaining it all
btw the tranny does same the same model number as the old one
Old 11-25-14, 04:57 PM
vegaswins
vegaswins's Avatar
Old 11-27-14, 07:26 AM
SC400slide
In Recovery Mode
SC400slide's Avatar
Start reading at post #33.
https://www.clublexus.com/forums/gs-...-thread-3.html
preston145
17
02-20-15 12:59 PM
mktbully
06-13-11 11:26 AM
klymax77
04-11-08 07:00 PM
sourcemine
06-06-05 05:50 PM
Quick Reply: gs300 transmission in a sc400
