EGR: to delete or not to delete?
Old 07-03-14, 11:30 AM
t2d2
t2d2's Avatar
Default EGR: to delete or not to delete?
In today's installment of "What Could Possibly Crumble Next?" my EGR Vacuum Modulator proved to be less solid than the dry rotted lower hose connecting it to the EGR Valve. My camera sucks at close-up pics, but you can sort of see the issue, which I think perfectly explains why I've had such horrific luck with every plastic item in the engine bay (and some in the interior) falling apart: there are air pockets throughout. I've never seen a car have so many plastic items fail, and I've never seen materials so shoddy. It all makes sense now.
Anyway, I've been reading over the pros and cons of deleting the EGR system the past couple days, and now's the perfect time to make a decision! We don't have emissions testing here, so that's a non-issue. Engine performance and longevity has no apparent consensus one way or the other.
Factors to consider include: ease of deleting (cutting cover plates), CEL override (I seem to have one of the cars with no 6-pin EGR connector to tie the resistor into), and draining the coolant to reroute those lines. (I guess I'll need to figure out where the drain plugs are on this car at some point!) Any other considerations?
There was quite a bit of loose carbon sitting in the metal tube at the valve side of the hose. I ran some of the EGR tests yesterday and I think the system may not have even been working... Wouldn't loose carbon get sucked through if vacuum were being properly applied?
Attached Thumbnails EGR:  to delete or not to delete?-p1010032-crumbled-egr-vacuum-modulator-base.jpg
Old 07-03-14, 11:44 AM
t2d2
t2d2's Avatar
On a positive note, I was able to wrestle free my PCV valve while working on the EGR area and finishing up new caps and rotors. That grommet put up a serious fight! I even managed to not lose any of the grommet, which no longer resembles rubber, down in the hole. One end of the PCV hose was cracked.
Old 07-03-14, 06:53 PM
bigwhite
bigwhite's Avatar
I think this debate has been had a couple of times on here, try searching this forum.
Old 07-03-14, 07:00 PM
t2d2
t2d2's Avatar
Seriously, did you read anything beyond the Subject line? It should have been pretty obvious that I've already searched and read up on the EGR Delete debate.
hbradberry
02-22-19 08:06 AM
mishkinm5
IS F (2008-2014)
25
06-06-18 09:24 PM
Neofate
30
05-09-16 01:02 PM
t66sc3
45
12-30-15 05:17 PM
mitmaks
10-19-15 12:28 PM
Quick Reply: EGR: to delete or not to delete?
