Probability I just need R134-A recharge?
Old 05-11-14, 03:16 PM
Biddles
Biddles's Avatar
Default Probability I just need R134-A recharge?
I have a 1996 SC400 and the AC doesn't blow cold air. It blows hot air fine, just not cold. What's the probability I just need a recharge? I know if I need compressor/drier it's like $1200 from Lexus dealer and $900 from a regular shop to do the work.
The car was has all been dealer maintained thus far, so what's the chance the compressor failed in this thing? Do they fail often? I'm only at 123K now hoping it's just a recharge. I need cold air regardless, just figured I'd ask on the failure rate. Anyway to easily diagnose it myself?
Old 05-11-14, 03:29 PM
michaelb20
michaelb20's Avatar
Happened to me ended up needing to get the heater control valve replaced. Pop the good and check out the heater control valve and see if there is any evidence of it leaking. The part costs about $300-$400 so it's pretty pricey.
Old 05-11-14, 03:43 PM
Biddles
Biddles's Avatar
No evidence of it leaking. I was thinking the compressor might be the problem though not the heater control valve, I thought that was for hot air only?
Old 05-14-14, 12:04 PM
michaelb20
michaelb20's Avatar
Well the heater control valve would be a less expensive fix compared to the compressor, but you should probably have someone look at it to determine the cause of the problem. For me I went in for service and the Lexus service tech was the one that informed me of my leaky heater control valve, and i remember the A/C wouldn't work properly (blowing hot air), as soon as I replaced the heater control valve everything worked and the A/C was colder than ever.
gmanjeep
07-10-13 04:30 PM
BlaineyB
03-15-12 10:35 PM
2jznosht
13
11-04-11 01:58 PM
ucmysc400
SC- 1st Gen (1992-2000)
12
12-08-10 03:52 AM
Mouse
12-10-02 04:57 AM
Quick Reply: Probability I just need R134-A recharge?
