V160 vibration problem
Old 09-07-13, 06:24 PM
97-SC300
97-SC300's Avatar
Default V160 vibration problem
Been having a problem with my sc lately. Anything over 3000 rpm in an gear I get a large vibration, here is a video I took. I can make it go away by pushing the clutch pedal in 20 times or so but it comes right back after 3000 rpm. An help would be great.
http://www.youtube.com/watch?v=PrlLL...ature=youtu.be
Old 09-07-13, 07:23 PM
stockhatch
stockhatch's Avatar
It looks like the input shaft of transmission, or throw out. Would have to tear it apart to fix regardless. Good luck with it sir!
Old 09-07-13, 08:34 PM
blk&blu*j
blk&blu*j's Avatar
Are you using the Stock FW (Dual Mass) and what clutch????
Was that video with the car in gear and free rolling off the ground????
Old 09-07-13, 09:17 PM
97-SC300
97-SC300's Avatar
RPS CC With the RPS Cromoly Steel FW.
Car was in second gear on a lift and got the RPM to 3000 when you saw how it started to vibrate. It does that in all gears while driving or standing still. Below 3000 its fine.
Old 09-08-13, 06:24 AM
jwin
jwin's Avatar
Looks to me like a throw out bearing since the clutch fork moves around so much from the vibration. Take the clutch fork out and see how the bearing is.
Old 09-08-13, 08:11 AM
1JZPWRD
1JZ Single SC400
1JZPWRD's Avatar
I also agree with Jwin on this one. Just by the video and what it appears to be doing.
Old 09-08-13, 09:47 AM
97-SC300
97-SC300's Avatar
Thank you guys, that's what I was thinking also its just weird cuz as you all know every single bolt, nut and part was absolutely brand new and I have only heard of throw out bearing making noise when bad and not causing vibrations like this correct me if I'm wrong here
Old 09-08-13, 11:04 AM
stockhatch
stockhatch's Avatar
It could also be the input flange. If that snaps or becomes loose, the throwout could possibly flop around.
Old 09-08-13, 10:40 PM
jwin
jwin's Avatar
It seems like some this out of round. Since everything oem Toyota is usually pretty good the only thing I would pay close attention to is the rps c/c clutch. The flywheel and pressure plate where the input bearing goes and where the hub rides on.
Old 09-09-13, 04:02 AM
97-SC300
97-SC300's Avatar
Thank you guys, i guess its time to take her apart once again
Fojo
02-24-16 06:40 PM
difred
11-29-15 11:21 PM
shui3000
02-27-09 05:46 PM
soarer1986
06-19-07 09:38 PM
Quick Reply: V160 vibration problem
