Can anyone recommend a good aftermarket 1JZ-R154 flywheel?
Evolution 1JZ-R154 flywheel?
Edit: simplified
I've searched around but I can't find anything conclusive on this. I've been trying to source a factory Toyota 1JZ flywheel but currently they aren't available.
I've been looking at alternatives. Does anyone have an opinion or experience on the Evolution 11lb lightweight flywheel?
I'd prefer the stock flywheel or a chromoly aftermarket but I'm not looking for anything crazy. This will also be going against an NA motor for now in all likelihood so I don't really want to lose all my low end.
Thanks!
Thanks!
I'm going to venture a guess that most of the aftermarket flywheels aren't that good on a JZ compared to a factory one.
I couldn't find any firsthand info on the Evolution flywheel. JUN seemed to be the only aftermarket one worth going to but I found a new OEM Toyota 1JZ flywheel today so my issue has been solved.
1JZ Single SC400
I bought the DM flywheel and never looked back. Very high quality and weighs around 11 pounds I think. Kinda expensive but well worth it in my book. I think the name was Evolution.????
1JZ Single SC400
It just so happen I pulled the tranny yesterday and replaced the rear main seal. I looked over the flywheel and it had one dime size color from being scorched. It maybe because of the ACT Stage 4, 6 puck clutch. I dont know. No other issues from what I can tell. It does help increase the quickness of the rev, but also could possibly loose when off the gas due to the lightness. Overall well worth the money for the purpose of having a lightened flywheel. I have over 500 rwhp and no issues from the flywheel. Period.
Just to be clear, are you using an R154 engine on an NA 2JZGE engine so you can go 1JZ/2JZGTE later down the line? Just sounds a little odd, might as well wait until you get your new engine and R154 combo together and slap the new flywheel on then.
When i put a Fidanza flywheel on my old 2JZ/W58 setup i did notice the revs climbed a bit faster than my old flywheel. The car also lunges a lot more when you let off the gas due to the quicker loss of momentum from the 12lb flywheel. Also i noticed my gas mileage in the city dropped off quite a bit after the install due the revs climbing quicker than before. You get used to it after a while. Fast foward to today, i still have the old W58 and fidanza flywheel, but this time it's hooked up to a 1JZ unit. Again same issues, but i've gotten used to the lunging on decel and gas mileage is not really a concern to me anymore (boost does that to a person). Overall i like my flywheel, just takes some getting used to
StiCk3, based on what your impressions are, I might be wary of the jerking you describe but I think it might be offset with having a decent amount of boost. It may not benefit me now but it may later on. Funny, gas mileage isn't much of a concern to me either even without boost.
You have, 1JZPWRD and StiCk3, thank you!
I've got most of the car sorted for a swap at this point. TT rear brakes will go in shortly once my new rotors come in. Then it's really just prepping the R154 and starting on the long road of converting a JDM 2JZGTE into a Cali-spec USDM GTE. After my conversations with one clueless BAR ref and one very knowledgeable BAR ref this week, I'm far less worried than I used to be.
1JZ Single SC400
I wanted to add to this also. If you need new bolts, I used the 8.8 Grade Fastenal bolts. They worked great and had no issues. Make sure to apply Red Loctite. The Evolution Flywheel came with a bracket to secure the bolts from backing out, sorta like a backing plate with tabs. Pictures of the this is in my signature below, around page 40 or so.
Hmhatch, I tried both Carson and Driftmotion two weeks ago and in both cases there was a stop-sale order applied to that part number for US customers. This, despite there being 20-30 in a warehouse in the USA at time of this posting. It's kind of the same thing that happened with the early R154 Soarer extended shifter housings and internal arms-- still available but disallowed from US sales. Apparently this stop-sale could change or not. it hasn't been applied to 1JZ bellhousings yet.
For the OEM flywheel I found one shop in Florida that had a few in stock.
1JZPWRD, thank you! I was planning on using ARP flywheel bolts but I wasn't sure if Loctite was needed. The factory non-reusable Toyota bolts are supposed to have some way that they don't allow backing out if you follow the manual procedure to the letter.
I'm going to check out your install thread to see this backing plate.
1JZ Single SC400
Your welcome. No problem. The backing plate is just another piece of mind, with the addition of the Loctite. I used the impact to loosen mine up, and they came right out, even after been in there for over a year. Don't be afraid to use it.
sdsupra
SC400 / 300 Classifieds
02-27-08 08:52 AM
