Clean Throttle Body with BG 44K or Sea Foam?
Old 11-26-12, 06:00 PM
speedmike
speedmike's Avatar
Default Clean Throttle Body with BG 44K or Sea Foam?
Is it possible to clean the throttle body using Sea Foam or BG 44K via your gas tank?
Old 11-28-12, 07:55 AM
Ali SC3
Ali SC3's Avatar
stuff from your gas tank goes to the injectors, which gets sprayed into the head. at no point in time whatsoever does anything in your fuel tank go through your throttle body, or even your intake manifold for that matter, just the last little bit of the runner right before the head.
call me old fashioned, but I start by removing the throttle body, spraying the inside with carb cleaner, and wiping all the gunk out. some people pour seafoam into the intake in front of the throttle body or spray carb cleaner, this is not that effective and any of build up that happens to get dislodged just ends up further into your intake manifold.
Old 11-28-12, 09:15 AM
cheez
cheez's Avatar
if u look up youtube videos of people seafoaming their cars, you'll see how they get it into their manifold. ive done it and it clears it up pretty well
Old 11-28-12, 11:04 AM
jschru
jschru's Avatar
i agree with Ali, best way to clean your tb is to just take it off and clean it by hand with carb cleaner. you can even use steel wool to polish up the inside a little bit and smooth out the air flow into the intake mani.
Old 12-03-12, 12:29 PM
Ichthys
Ichthys's Avatar
Default removing and cleaning throttle body
I've been looking for instructions with pictures for removing and cleaning the throttle body on my 2010 RX350.
Can anybody help?
Old 12-03-12, 01:24 PM
StiCk3
StiCk3's Avatar
Can anybody help?
kinda wrong sub-forum to be asking this...last i checked RX350s had 2GR engines, not 2JZ
Old 12-11-12, 06:43 PM
MyLexs400
MyLexs400's Avatar
Default Throttle and intake cleaning
Throttle and intake cleaning can also be effective using a pressurized setup. Ive seen a nice setup from Wynns specifically designed to clean out the intake system. The Wynns one ive seen sprays out a fine mist through a nozzle that can be inserted in the intake after the maf/filter. This would give you a completly clean intake system vrs inserting a vac hose into a can of seafoam which could be risky if done incorrectly. Most dealers have something like that but cheaper to have it done at an independent shop.
LsG86
02-27-15 04:20 AM
Options2k
GX - 1st Gen (2004-2009)
06-03-12 07:03 PM
Stage3
Maintenance
01-08-08 07:05 PM
ShowGSLuVv
Performance
09-23-02 05:03 PM
Quick Reply: Clean Throttle Body with BG 44K or Sea Foam?
