93 sc300 tranny issues AGAIN
Old 04-30-12, 08:56 PM
trinils97
trinils97's Avatar
Default 93 sc300 tranny issues AGAIN
Ok I'm totally fed up with this car. I've exhausted every option I can think off . Where do I start , the car was pulling off in the wrong gear , the over drive light kept flashing . I changed the trans fluid an filter even changed the shift selonoids . Car ran fine for about a month then started back doin the same. Finally I said ill swap out the tranny did that it worked fine for a half hr went back not shifting properly . Swaped the ecu same thing worked fine for a while now its back to the same thing.. I had a friend check the codes an I got 61 63 64 . I'm seriously about to junk the car . Any input @ this point would greatly be appreciated
Old 05-01-12, 07:04 PM
trinils97
trinils97's Avatar
Umm anyone?
Old 05-01-12, 07:40 PM
kevint2
kevint2's Avatar
Hard to say...If your OD light is on then something inside the the trans is not right...I have a friend the had the same problem and turned out to be a shift solenoid and needed a rebuild,,he just did a 5speed swap and was done with it..
Old 05-01-12, 07:56 PM
Rising_Sun
Rising_Sun's Avatar
Transmission OBDI Diagnostic Codes
42 - No. 1 speed sensor signal malfunction
46 - Open or short circuit in no. 4 solenoid valve
61 - No. 2 speed sensor signal malfunction
62 - Open or short circuit in no. 1 solenoid valve
63 - Open or short circuit in no. 2 solenoid valve
64 - Open or short circuit in no. 3 solenoid valve
67 - OD direct clutch speed sensor signal malfunction
68 - Short circuit in kick-down switch
I hope this helps
Old 05-02-12, 08:32 PM
queenskid9
queenskid9's Avatar
Hey guys Im the friend that tried to help with the issue. Again he's getting code 61, 63 and 64.. Aren't 63 and 64 directly related to 61 the speed signal? I saw a link that may be related and also help a previous car i worked on but not sure if it will help this issue.
http://www.supraforums.com/forum/sho...light=flashing
post # 9 and post # 13
Old 05-03-12, 02:24 PM
trinils97
trinils97's Avatar
What's gd bro appreciated the help it don't even matter anymore got rid of the car lol . Now its on to the next one
Old 05-03-12, 02:31 PM
sj408
sj408's Avatar
hey how did you guys check trans codes? i seem to be having similar issues, new solenoids fresh fluid and filter and it pulls off in second gear unless i jam my foot all the way into the ground to hit the button.
also the damn thing wont downshift into first even at super low speeds 5-10 mph it just creeps off slowly in second. my 94 gs300 will spank my sc just because the trans shifts perfectly.
Old 05-03-12, 03:08 PM
bryan767
bryan767's Avatar
not sure if this is related to your issue but theres a gear indicator that the shifter connects to on the transmission that you can turn to adjust. maybe its out of alingment?
Old 05-04-12, 09:53 AM
sj408
sj408's Avatar
so where exactly you say its located??? its where the actual shifter links up to the trans??? in what way can it be adjusted??? is it just to show which position the shifter is in or does it have another function.
very interested cause i just hopped in the gs300 i bought and the trans shifts flawless and now i hate my sc.... almost feel like making it stick but im really against that right now.
can anyone chime in on the procedure to read trans codes? i assume its not just te1 to e1 like obd1 retrieval
Old 05-04-12, 10:41 AM
bryan767
bryan767's Avatar
https://www.clublexus.com/forums/per...-properly.html
its on the passanger side of the transmission, mounted on the side where the coolant lines go.
Old 05-04-12, 01:37 PM
sj408
sj408's Avatar
yeah after reading that probably completely unrelated, seems that only has affect on shifter position and indicator lights.... im talking about my trans wont downshift correctly and upshifts even when trying to accelerate
Pass V1
GS - 1st Gen (1993-1997)
11-13-11 05:07 PM
ric4044
SC- 1st Gen (1992-2000)
19
09-27-10 10:33 PM
ariasuriah
07-06-09 05:25 PM
trufanatic
10-31-08 08:33 AM
sc250tt
08-06-06 06:39 PM
Quick Reply: 93 sc300 tranny issues AGAIN
