What kind of car is this 1jz harness from?
Two row ECU plugs = JZA70
Three row ECU plugs= Chaser/Mark II/ Soarer/ Aristo
Seeing that it only has two usable plugs at the end I would say it's a Chaser/ MarkII
You need a ECU plug from any mid 90's V6 Toyota Car to power up the ECU, since it looms from a body harness patch. Time to hit the junkyard.
Sorry i dont mean to thread jack but im in a similar situation. Im go to attempt to do a little wiring for my friends 1jz swap. Its clearly not a jza70 harness since it has 4 rows of pins. My situation is that the body plugs have been cut. Just wanted to see if you guys have any info on the pinouts for the body plugs or have any suggestions. Id prefer to not have to trace every single cut wire. Thanks in advance.
Let me know if you find one. Im sure its floating around here somewhere. Ive checked the diy 1jz swap section, but i can only find the ecu pinouts. From there i can wire a few wires to the body plugs, but not all of it.
