Coolant Leak @ Back of Engine...Pull Trans or Engine?
Old 02-05-18, 08:12 AM
TyStephens
TyStephens's Avatar
Originally Posted by CRuby
Replacing the Oring at aft end of inlet housing did the trick for me. That was a piece of cake after messing with the trans.
Be sure to check the valley on top of the block to look for coolant puddled there. Mine had it, I just didn't check up top first, & jumped to the (wrong) conclusion that it was between engine & trans, where I saw the drip. It's kindof like the leak I had in my roof. Where you see it dripping is not necessarily where it's leaking.
Was your drip accompaied by a fair amount of steam? I crawled under the car yesterday becuase I had steam coming from behind the motor, and could see it leaking down in the same place but have yet to check the valley as you suggested.
Thank you!
kizzle
12-27-18 09:57 AM
bmxkeeler
11-05-13 05:36 PM
SC300_704
Southeast
07-19-09 10:08 AM
cambo
11-24-06 01:42 PM
ken8817
GS - 1st Gen (1993-1997)
06-30-06 09:57 PM
Quick Reply: Coolant Leak @ Back of Engine...Pull Trans or Engine?
