Coolant dash light on, but level is normal. Any ideas?
Old 08-04-11, 04:51 PM
92 SC400
92 SC400's Avatar
Default Coolant dash light on, but level is normal. Any ideas?
So, as my tittle states, my coolant light illuminates but the actual level looks fine. The light typically does not come on until the car is at normal operating temps. At times it will intermittently turn off as well even at normal driving temps.
There aren't any visible leaks and the radiator was changed like 4 years ago or so. Any ideas what's causing this to happen?
Old 08-05-11, 06:55 PM
MMCtuner
MMCtuner's Avatar
Check your oil level. If yours is a 92 Sc400 I think it won't came with low coolant light.
Old 08-05-11, 08:55 PM
NaturalJZ
NaturalJZ's Avatar
Check your oil, i know on my m3, i was getting that due to bad headgasket. Check the oil to see if its creamy at all from mixing with the coolant.
rkyat
SC- 1st Gen (1992-2000)
08-11-07 02:56 PM
RedPhoenix
04-21-07 08:56 PM
CELICA XX
10-07-05 05:26 PM
MatT3T4
03-22-03 11:15 AM
Quick Reply: Coolant dash light on, but level is normal. Any ideas?
