What the hell? please help
Ok guys so i have been having problems with figuring out what tranny i have. My car will not upshift out of first gear no matter what, After some research i decided to go back under car and i have looked around and noticed a plug dangling, has one pink an done violet wire 2 plug. Did more research this plug is the out put signal to the second speed sensor(speed sensor #2) which controls shifting, So viola thats why my car isnt shifting bc it isnt getting a signal. Speedo works, so number 1 is right and working. Now what the hell comes in as there is absolutly no place to plug the second sensor in. What tranny do i have, and i cant read the serial number on the transmission. And please don tsay are you sure theres not a place for it. I dropped the tranny down and there is no place on top for the sensor. so my question is how do i get signal to my tranny to tell it to shift????? do i need to find another tailhousing which has the sensor on it? please help guys
1992 sc300(auto), soarer harness, jzz30 ecu
1jz chaser engine, harness dun by tweak. bought the car with swap already installed but was running or finished. today was first time it has been driven. was done professionly yes. there is no where on the tranny to plug in the second speed sensor?
Ok, have done a bit of reading, and seems that the JZX90 came with the a341e, but I have also found some argumentative info stating its a possible a342e transmission.
There has to be a plate somewhere on the transmission and it will simply either state:
Aisin 30-41LE
OR
AFAIK A341LE or A342LE
But what I would do, if you know for a fact that the harness was done by Phoenix Tuning, contact them and explain the issue to them that you have an extra plug and the transmission inst shifting.
That might not have been much help, but hopefully someone can clarify on the transmission a bit more.
Aisin 30-41LE
OR
it is definately Aisin 30-41LE i couldnt read the 0 but thats what im guessing the next number is on the blue serial tag. So what does this mean ? i still cant find a location for a second speed sensor on that tranny. without that sensor or a signal my tranny will not shift.
thanks eldon ok son soarer central they are saying that the a341e came in the chaser which makes sense as i have the chaser motor. also found another guy on the forum who said he did the swap in his jza80 and had one little two plug hanging yest his works fine. im gunna set this car on fire.
