Proper W58 for the sc400 Swap
Old 11-15-10, 10:33 PM
tjfrom215
tjfrom215's Avatar
Default Proper W58 for the sc400 Swap
Hey everyone,
So my swap is close, Im excited to see that
auto stick leave and bring my car to life,
I know I have read about various W58's, say if
they are off a supra mk whatever? or a sc300,
what one would be the best for the swap?
if a sc300, what years? if a supra what years?
ide appreciate the help.
thanks everyone.
Old 11-20-10, 02:38 PM
LP1
LP1's Avatar
I used a JDM W58 but have seen the same set up from a later model Supra NA. The shifter extension is about perfect, has the electronic speedo sender and allows the use of a short shifter. That's a R-154 in the back with the JDM extended housing, we ended up fabricating an extension for it.
Old 11-21-10, 03:03 PM
RedPhoenix
RedPhoenix's Avatar
ANY MK4 Supra W58 or SC300 W58.
Any of those... no MK3 Supra W58...
Old 01-18-11, 11:17 PM
soneencris
soneencris's Avatar
how about a w58 from an is300?
Old 01-19-11, 04:32 AM
RedPhoenix
RedPhoenix's Avatar
Nope. Its the same issue with the MK3 W58, except it has not been explored yet. We know the issues with the MK3 W58 and it is no bolt in affair, ie we used a welder 2 different times to get it all to work.
Old 01-19-11, 04:33 AM
RedPhoenix
RedPhoenix's Avatar
and its a W55, not a W58, its weaker
Old 01-19-11, 05:30 AM
BartleDoo
BartleDoo's Avatar
Unless you want to make your own Frankenstein transmission mount out of the SC4 auto and MKIII manual and then put together a shifter puzzle...You probably don't want the MKIII.
Old 01-19-11, 10:26 PM
soneencris
soneencris's Avatar
I'm confused? There is a w58 for sale locally, seller says it was removed from an is300. How can I tell the difference? What do I look for? I appreciate the help.
Old 01-20-11, 05:33 AM
BartleDoo
BartleDoo's Avatar
Well get him to send some photos of it and post them for one. Then we can analyze. Unless he swapped in the W58 it is a W55, though.
Old 01-20-11, 05:38 AM
RedPhoenix
RedPhoenix's Avatar
A lot of IS300 owners think they have a w58 in it cause all the newer toyotas had that... but they are wrong wrong wrong.
Old 01-20-11, 10:10 AM
Ali SC3
Ali SC3's Avatar
yes is300 does not use a W58, these guys are correct and the w55 they do use is much weaker than a w58 and I would not consider putting it behind the v8 for a second.
you need one from an sc300 or a mk4 supra, if you get the 95+ you will get the newer style remote tailhousing but this is not necessary, any of them from the above cars will get the job done.
If you want to use a mk3 trans, forget the w58 and do the R154 swap, dont they make the adapter plate for those as well?
Old 01-22-11, 03:52 PM
Meanshyguy
Meanshyguy's Avatar
Thanks for the info, I had this question too but didn't wanna make a thread about it and be told to search!!
Old 01-22-11, 07:04 PM
BartleDoo
BartleDoo's Avatar
WELL SEARCH ANYWAYS!! Just kidding, but excessively researching will always build your comfort level for any undertaking anyways. So search on.
Old 01-26-11, 05:13 PM
squrilbait
squrilbait's Avatar
i got my trans from a 91 supra with the extended housing its susposed to be the same as the first years of the sc300 if it doesnt fit the way i want it to its getting a hack and slash job on the shifter so it will fit i will let you guys know how it goes.
Old 01-26-11, 05:25 PM
BartleDoo
BartleDoo's Avatar
You're going to have to make a custom transmission mount also.
Quick Reply: Proper W58 for the sc400 Swap
