supra radiator with SC shroud
I was wondering if anybody has any good ideas that they have done to mount the sc fan shroud to a supra radiator with a little modifications to the shoud as possible? I was thinking of making a little bracket to go from the radiator to the shroud. I have a Griffin radiator if that helps at all.
LoL I have a griffin rad with the SC shroud. Mine got a little banged up so I just used an L shaped bracket that i made and bolted it from the top. I also had to cut up the bottom around the lower rad hose is to allow it to fit properly because the SC shroud is taller than the supra rad. other than those two mods it fits just fine i could take a pic tonight when i get home if you like
I know that it doesn't fit properly but I was just wanting to see what other people have done to help make it fit better. Through some searching I've read that many people have to get a supra water pump pully and fan to use the supra shroud. Do you know if is that true? I've read some mixed messages.
Deegee
SC- 1st Gen (1992-2000)
10-31-15 02:40 PM
