Vibrations When 5spd swap w58 help.
I swap my auto tranny to Manual (w58). i used the Front piece driveshaft of a manual DRSHft and the Rear of a auto DRSHft. But when i drive it vibrates at 30 miles and it continues. what can it be. Help
SC300 94" w58 Swap.
SC300 94" w58 Swap.
Try unbolting the driveshaft sections, rotating it one bolt hole, and driving it......if that doesnt fix it, you can try that 2 more times....lol the 5 speed mounts are diffferent, but the crossmembers are the same....
Man bolting up two completely different driveshaft sections and this is gonna happen.
Like GSpec said try to rotate the front section so that the balance weights are on the same side of the front and rear shaft. If that doesn't work get it rebalanced locally.
The trans mount wouldnt cause that kind of vibration unless it's totally missing so you might as well replace it if its questionable.
