Sc300 2jz gte swap boost question
Old 03-27-10, 11:54 PM
1996sc300
1996sc300's Avatar
Default Sc300 2jz gte swap boost question
hey
i have a 1996 2jz gte swap
my question is the swap is pretty much stock motor with the exception of front mount, bov, straight pipe.
i am hitting fuel cut at 18 psi
can a manual boost controller be used to set the boost back to 14 psi so i do not hit fuel cut.
i read about the HKS fuel cut system but wonder if the manual boost controller will lower my boost.
Thanks alot
Old 03-28-10, 02:56 AM
Zar
Zar's Avatar
Boost controllers can adjust how much you boost, but if your wastegate is opening at a certain psi, no matter how much you adjust the boost controller, it will not make the wastegate open earlier.
Vwpride12
Build Threads
269
12-04-16 04:14 PM
Golden95SC
11-18-13 02:02 PM
GTE4Life
05-24-13 01:24 PM
PMP 300
Performance
26
01-30-12 09:08 AM
97-SC300
SC400 / 300 Classifieds
09-21-11 01:55 PM
Quick Reply: Sc300 2jz gte swap boost question
