how does the PS pump spring and retainer type thing go back in?
Old 02-05-10, 05:04 PM
SRT102JZ
SRT102JZ's Avatar
Default how does the PS pump spring and retainer type thing go back in?
for those of you that have changed out your PS line:
i changed out my leaky PS line with the driftmotion line yesterday and the install went smoothly, so i thought.
when i removed my stock line from the PS pump, i made a mistake and removed the other bolt that goes between the PS line and PS pump. Right after i removed that, a pretty large spring and a cylinder type shaped metal piece both fell out of the now open hole in the pump and fell onto the ground.
well i put the spring and metal piece back in how i thought it should go, put fluid back in, did all the normal stuff for getting the air out of the line and then test drove the car...now I have NO power steering at all so im assuming i put those two parts in wrong.
does anybody have any idea how these two pieces are supposed to go back in? I can go out and remove everything again and pull the two pieces and take a pic of them if it would help.
Heres a pic of the bolt that i removed that caused the two pieces to fall out:
Old 02-06-10, 05:30 PM
SRT102JZ
SRT102JZ's Avatar
Anybody? I need to get this fixed
Old 02-06-10, 07:00 PM
LEX_MAN
LEX_MAN's Avatar
Just take it out and try something else i guess.
PZski
Maintenance
08-25-14 07:11 AM
whattaGS
GS - 1st Gen (1993-1997)
09-05-11 03:34 AM
Amskeptic
01-26-10 06:00 PM
Biggu
03-18-09 06:45 PM
Quick Reply: how does the PS pump spring and retainer type thing go back in?
