Noob ? GE GTE Questions
So i wanted to make my ge a gte and just throw on the parts needed like the turbo, mani, exhaust mani, intake mani things like that
but apon further research im hearing the ports on the gte differ from the ge?
can anyone clarify before i go buying all these gte parts that dont fit?
oh boi.......... i will give you a quick run down before you get flamed.. The blocks are basically the same minus some internal stuff the head is different the wire harness is different so is the ecu. oil pump is different transmission is different and thats just a few things you would need to buy to convert from GE to GTE everything can bolt up to ur GE block but imo its not worth doing a conversion just swap in a complete GTE and just get the harness and ecu done or just go NA-T (better choice)
Neu`roc´i`ty
Lets start small....read all of this.
http://www.intellexual.net/faq.html
