Sc400 gurgling sound/ hot exaust
Old 11-08-09, 09:26 PM
Kodachi
Kodachi's Avatar
Question Sc400 gurgling sound/ hot exaust
Hey everyone, my 1992 sc400 had a new timing belt and water pump installation. Everything is ok except at low rpms it struggles like there's a small lack of power. The exhaust makes a low gurgling sound and it seems like it gets to hot to quick. I hear sc's are notorious for there engines to run hot. I read somewhere that when your cats clog it can cause power loss and the exhaust can heat up extremely quick. What do you guys think?
Old 11-08-09, 09:48 PM
khutch
khutch's Avatar
Check your coolant levels. Air can get in the lines and that could be causing the sound. You should always check them after a couple days after getting any kind of work done to your cooling system.
Old 11-09-09, 06:35 AM
Kodachi
Kodachi's Avatar
The coolant level has been at a steady level where its supposed to be. I haven't seen any change. When I first got the car done(about 5 weeks ago) I was having problems with the temp raising to the hot level, so I bleed the coolant system and its fine, but its almost always a little above the mid point on the temp gauge.
srmlexus
11-20-23 10:43 AM
Slickcam
GS - 1st Gen (1993-1997)
03-12-16 07:38 PM
Onisar123
IS F (2008-2014)
09-23-15 07:09 PM
ultimohero
SC- 1st Gen (1992-2000)
12-13-10 11:33 PM
Quick Reply: Sc400 gurgling sound/ hot exaust
