Where O Where do my hoses go? W/pics
Old 10-28-09, 10:49 AM
ProjectLex
ProjectLex's Avatar
Default Where O Where do my hoses go? W/pics
If I get these hooked up, 1jz swap is all but finished. Help ASAP, my buddy is closing his shop and I need this car rolling, not towing.
If you have questions before you can offer a suggestion, please ask. We are a bit stuck on this.
TIA!
Old 10-28-09, 11:37 AM
Papajorgio
Papajorgio's Avatar
it looks like the heater core hoses, but unsure of 1jz setup but you could run it and see if coolant starts pouring out, if so theres your answer, you could cap it off if your not intending on using your heater, hope this helps
Old 10-28-09, 12:02 PM
DRFTSC400
DRFTSC400's Avatar
Looks to me like the hose in the first pic goes on the fitting on pic #3. Its a water hose that's for sure. The second one I think you can plug it.
Old 10-28-09, 01:12 PM
Ali SC3
Ali SC3's Avatar
longshot, but that hose in the first picture could totally be the fuel return line hose that hooks up near the oil filter.
a quick sniff will tell you if its fuel related or water related.
Old 10-28-09, 01:22 PM
OneJay
OneJay's Avatar
Need to hook #2 up to #3. That is a coolant line to the heater core.
If that hose in the first pic connects to the back of the block, you need to connect it to the heater valve inlet that you can see in the top of the 2nd pic.
That's how all mine are hooked up and my heater works great!
Old 10-28-09, 01:26 PM
BSC300TT
BSC300TT's Avatar
i will have to go out and look at mine but I know that picture 1 should run across the back of the firewall to a solenoid for the heater core (you can see it in the top of 2) and Im pretty sure that 2 goes to 3. I need to double check that for you though.
Old 10-28-09, 01:28 PM
BSC300TT
BSC300TT's Avatar
Just saw your post onejay.... glad you and I are both on the same page. Off topic but I talked to you a while back about your radiator pipe and where you got it, but cant remember where you said. Could you pm me please.
Old 10-28-09, 01:30 PM
TURBO819
TURBO819's Avatar
Default Pirated Picture From SC300TT
The First Looks like the line for the Heater Core
The Third picture looks like the Heater Core
Attached Thumbnails Where O Where do my hoses go? W/pics-2jzgte_diagram.jpg
Old 10-28-09, 02:34 PM
HeisLegend
HeisLegend's Avatar
Stole the words out of my mouth.
I don't have a 1j and never had, but just by looking you can pretty much tell what's what....more of an educated guess, really. haha.
just sr/honda swap background here....for now.
So, OP, did you get her running?
MrFairlady
SC- 1st Gen (1992-2000)
14
02-03-15 09:49 AM
GsLex00
11-20-13 02:13 PM
s1984
01-24-13 07:39 AM
joe diego
09-09-10 01:07 AM
mtnman82
02-21-10 10:22 PM
Quick Reply: Where O Where do my hoses go? W/pics
