Mounting a MKIV Stock Intercooler
Does anyone have instructions or a how to on this?
Will the same stock intercooler piping work on a sc300 and can I mount it in the same location as the supras?
Appreciate the feedback, a search came up with that it should work but now sure on the specifics thanks
See Post # 29
See Post # 29
https://www.clublexus.com/forums/per...to-2jzgte.html
All the Supra TT pipes fit wihtout modifying
It's still raining over here. In the first two pictures you will see the bracket I made using HOME DEPOT metal. All that was needed was a simple 90 degree bend and a few cuts. You could also see the mounting point I used. No cutting or drilling. No other modification is needed
Dude! Where were those pics when I was killing myself with this.
Anyway, mine is similar. Page nine of my build thread(sig) has some pics. Not quite as up close, but same idea. I did actually drill through the body below the intake air box, but 819's mount looks a little less troublesome.
Great thank you for your help man!!
I watched your video too, and I saw that you had cut the fender liner out from behind the IC, thats not needed right? I think supra TTs have fender liner
