car smells lean...
Old 05-21-09, 03:49 PM
SC300_704
SC300_704's Avatar
Default car smells lean...
well i currently replaced the spark plugs, wires, cap and rotor and when i turn on the car it smells lean and idle is a little higher now(about 1100rpm). before i did the tune up it usually smells very rich whenever i turn on the car. is this normal? btw i just used some ZMAX the very same day of the tune up....
Old 05-22-09, 06:39 AM
Deepa
Deepa's Avatar
Maybe try pulling the EFI fuse for a minute and let the ECU reset.
Old 05-22-09, 07:06 AM
LexusFTW
LexusFTW's Avatar
So you can smell if your car runs lean or rich? Impressive!
Old 05-22-09, 07:10 AM
craaaazzy
craaaazzy's Avatar
^^^ my thoughts exactly. especially the lean part. if running rich, u can smell gas, understandable. the opposite isn't always true...no smell could also mean u are running correctly, no?
Old 05-22-09, 07:22 AM
2jzlex
2jzlex's Avatar
You can smell when it's lean...... huh. What exactly does that smell like?
Old 05-22-09, 09:14 AM
SC300_704
SC300_704's Avatar
lol...i guess it's running ok then haha, but it does have a weird smell to it just doesn't seem normal to me.
Old 05-22-09, 09:19 AM
TLDriver
TLDriver's Avatar
plug in a a/f meter and it should tell you how it's running
Old 05-22-09, 09:23 AM
SC300_704
SC300_704's Avatar
uhh..to cheap to buy a wideband at this time.
Old 05-22-09, 02:29 PM
TLDriver
TLDriver's Avatar
ask a friend? I have a narrow band A/F meter that you would be able to use... but your far away hahaha
Old 05-22-09, 05:16 PM
ucfa4
ucfa4's Avatar
I dont think it is good to smell your exhaust but i may be wrong. You should get someone to test it.
Old 05-22-09, 07:09 PM
SC300_704
SC300_704's Avatar
i'm thinking it's just the zmax cleaning the gunks inside the engine, kinda like seafoam.
Old 05-22-09, 07:42 PM
Durrr
Durrr's Avatar
ive been thinking about it for a few hours, and the best way I can describe the lean exhaust smell (been dealing with carbureated rotaries for a while) is it's like burned propane from a gas stove. If you really are lean, then you can tell by the temp of the cats (if you have them or if you dont) you really need a wideband and a dyno. GL!
Old 05-22-09, 09:04 PM
2jzlex
2jzlex's Avatar
Epic......
Old 05-23-09, 09:27 PM
booja
booja's Avatar
narrow band af meters do not tell you anything except that the gauge is getting power and now theres a light show in your interior
Old 05-23-09, 11:51 PM
bens sc
bens sc's Avatar
+1 A narrow band isnt gonna tell you crap.
nateew92
12
10-17-17 10:48 AM
Scjunky94
11-16-16 04:14 PM
UNDR8D
21
09-26-12 04:57 PM
ImWildBill
22
10-07-11 08:18 AM
b00stme
SC- 1st Gen (1992-2000)
09-02-10 10:21 PM
Quick Reply: car smells lean...
