Auto trans not kicking down
Old 05-20-09, 09:24 AM
Easy2speed
Easy2speed's Avatar
Default Auto trans not kicking down
I bought an Aristo swapped '97 SC300, and the trans never kicks down. I am going to put an R154 in, but I figured I might as well try and fix this until then. It is supposed to have the Aristo Auto Transmission, but I may have been scammed and it is the stock transmission. Any ideas?
Old 05-23-09, 11:26 AM
Spooled
Spooled's Avatar
There's a kickdown cable, which looks alot like a throttle cable, usually attaches to the throttle body, and routes back towards the transmission.
It could have either not been installed, is out of adjustment, or is loose at either the throttle body, or inside the transmission (which would involve dropping the transmission pan to re-install), or even worse, broke during install. I've seen them break numerous times.
Making sure that cable is intact or at least appears functional would be your best bet for starters.
Old 06-19-21, 08:18 AM
papiosc
9th Gear
papiosc's Avatar
Any ideas on where to source a transmission throttle cable? The one on my 93 SC4 is functional, but the plastic housing at its base is partialy split. Part is discontinued and unavailable through Lexus and searches on eBay and salvage yard networks has been fruitless.
LS400_96
26
07-31-21 01:05 PM
dimagurr
01-24-17 12:46 PM
CPALex
Performance
08-09-11 01:38 PM
pingu
04-10-09 09:57 AM
Quick Reply: Auto trans not kicking down
