2jz swap engine stalls when fan turned on
Old 05-12-09, 10:02 PM
DKNY0331
DKNY0331's Avatar
Default 2jz swap engine stalls when fan turned on
i got the jdm swap inengine runs good, it rips up and down the road . but when i tried to to on the heat by selecting the fan spped the engine stalled right away.. so i pulled the heater fan relay and tried starting the car.. car wont start as i pluged it in i heard the efi relay click.. so i pulled apart the junction block 2 which is the one under the hood.. and found out from the factory oem one white with a black tracer wire goes from one terminal of the heater fan relay and connects to one terminal of the efi relay.. and from there it goes into the body harness.. i havent got a chance to anything else other than hooked up an extra ground from batter to chasis but made no diffrence.. any ideas? i know weird..
Old 05-13-09, 10:34 PM
DKNY0331
DKNY0331's Avatar
nvrm guys i already figure it out! the heater fan relay and efi relay share the same ground, they end up bolting to the driver side inner fender underneathe the plastic harness for the body harness between the junction block 2 and fender.. the wires were hidden so i never figure i should bolted the one bolt i never bolt back on. easy fix
JettCRX
RX - 1st Gen (1999-2003)
18
05-31-22 07:46 PM
bigtiger88
HS 250h Model (2010-2012)
01-01-19 12:04 AM
uhjohnson
05-11-14 07:29 PM
Nazar
GS - 1st Gen (1993-1997)
02-27-07 06:47 AM
lsflame
06-12-06 10:51 PM
Quick Reply: 2jz swap engine stalls when fan turned on
