Can someone help with diff question????
if its like a 92 sc300 you just take the drain bolt off the pass. side of the diff and let it drain(jack the car up higher on the driver side to drain the fluid better.)
and then pump the new fluid in until its full.
BOOM your done.
BOOM your done.
This is for the LS400, but it is the same procedure.
Differential oil how-to:
http://lextreme.com/differential.html
