SC300 Oil Capacity - Technical Service Bulletin
Just wanted to share this with everyone especially the 92-93 SC300 owners.
It seems that I should have been filling with 4.5q instead of the 5.5q that I normally use. The apparent overfilling, over a span of ~15k miles, could explain some of the wet components on the under body.
Edit: Production date should be on the driver's side door, thanks tularisgp.
Hope some of you can find this information useful.
Here is the TSB from '94:
PRODUCT GENERAL INFORMATION
PG94-003
SEPTEMBER 30, 1994
SC 300
Title:
ENGINE OIL CAPACITY (REVISED)
The information provides new engine oil quantity recommendations for the SC 300.
PG94-003
SEPTEMBER 30, 1994
SC 300
Title:
Yup this is from Alldata. If you go into the fluid capacities section on the front page all it says is to fill with 5.5q. They may have been assuming that my 93 sc300 was produced in 93. If you dig further into the fluids section and use the TSB link on the right side, you can find this information.
My last 5.5q oil change was a couple thousand miles ago. I just checked the dipstick the other day and the level was a tad above the High/Low midpoint. For the next change I'll start off with 4.5q and add accordingly...
